mikepokeeffe
RF Layout for TD1208R and TD1508 (US)
by mikepokeeffe Fri Sep 09, 2016 9:41 am
I'm not sure if this should be in Hardware or Antenna's.
I'm currently designing a product that I want to work in both Europe and the US using the TD1208R and the TD1508.
There's a recommended layout in the TD1508 datasheet in Section 11.4.2, which is excellent.
Do you have any recommendations on having a dual optional antenna approach, one U.fl connector for the TD1208R and one U.Fl and matching circuit for the TD1508??
I'd imagine for the proposed circuit in Figure 7 a microstrip layout would work out better?
Thanks in advance,
Mike O'Keeffe
Re: RF Layout for TD1208R and TD1508 (US)
by mstempin Thu Oct 20, 2016 3:04 pm
You can use the same antenna for both 868.13 MHz and 902.8 MHz, as the SWR will stay < 2 in both cases.
Thus, the recommendations for TD1508 also apply for the TD1508R, and you can design a board that can support both modules.
Users browsing this forum: No registered users and 10 guests
