sg_34
TD1207R routing
by sg_34 Wed Aug 03, 2016 4:13 pm
I've a deign based on TD1207R : I'm looking for information on PCB routing :
- Are PCB or Gerber files available for EVB Board?
I'm looking for informations about ground plane and net under the module : my board is two layers, I planned to put a ground plane on the Top and the Bot layer, with via stitching.
I've read datasheet :
- no net under the module near pin 23 and 24 (area 4*4mm) so no ground plane in this area ?,
- is it possible to have net under the module? Top Layer and / or Bot layer
Thank's for your help and feedback
Best regards
Users browsing this forum: No registered users and 2 guests
