axelC
Routing rules
by axelC Mon Feb 22, 2016 10:03 pm
I am currently routing my PCB for a TD1204.
The datasheet speak about a " No routing wire area" near the RF pin (39,40,41).
Just to be sure, no wires are admitted under this area but I still have to include my ground plane there?
Or do I have to remove all copper on all layers in this area?
I actually have the same question about the UFL connector that I put on my PCB ( 1688077 @ Farnell )
The datasheet tell about a " Cut Out Prohibition Area". Should I put my ground plane in this area?
I am french that why I want to be sure of the translation of those area.
Thanks for yours confirmation.
Re: Routing rules
by mstempin Tue Feb 23, 2016 2:21 pm
There is an RF test pad below the TD1208 module in the RF pin (39,40,41)) vicinity, so you should avoid routing signals in this area, but of course a ground plane is OK, and even recommended there.
Same for the Hirose U-FL connector: don't route signals between pins, but put a ground plane instead.
Re: Routing rules
by disk91 Thu Mar 17, 2016 7:07 am
mstempin wrote:Hi,
wahoo ! datasheet was not really clear ...
Users browsing this forum: No registered users and 10 guests
