TD1208 Power Supply (3,3 V or 3,0V) LDO or switching PS
Posted: Mon Nov 02, 2015 4:47 pm
The recommended typ. power supply for the TD1208 is 3,0V, But the max RF power (14 dBm) is specified at 3,3V.
Therefore, I assume if I use 3,0V instead of 3,3V I won´t have the 14dBm, right?
Furthermore, the LDO on the TD1208 EVB is rated at 3,3V.
I would like to squeeze as much RF power as possible. Could you, please, confirm If I can use 3,3V wihtout risk.
Regarding the power supply (LDO or Switching P.S.):
You use LODs in your EVBs, but I am planing to use a switching power supply so I can take use of the full range of the battery. Do you have any feedback/suggestion about switching power supplies with your modules?
