it seems that I'm having an important and consistent shift in the position measured by the GPS.
I've forced it to have a 3D fix with a horizontal accuracy smaller than 60 m and the coordinates that I'm getting back do not correspond with my actual location (about 10 km error).
I have a question, does the GPS data come in standard WGS84 reference system? If I have correctly interpreted it, where does this error come from?
EDITED: I've used the u-center in order to check the GPS directly, it seems to work perfectly, the problem is in my software or in the libraries not parsing correctly the GPS data. I'm using a TD1204EVB with an external active antenna.
EDITED 2: To check, I've loaded the example "geoloc_fix" and it also presents the same error as my code. Can anybody replicate this error?
Germán
