Questions and discussion about the geolocalization features of the TD RF modules.
axelC
Glonass
by axelC Fri May 27, 2016 9:33 am
The TD1204 is glonass compatible.
Does that mean that it automatically switch to glonass instead of gps if it is better or does it has to be set manually?
Re: Glonass
by lcheminade Fri Jun 17, 2016 1:44 pm
Glonass is off by default. Unfortunately we don't have any API to enable it yet. I guess we might be able to provide it if needed.
Please note that this will increase consumption and will require having a GPS and Glonass compatible antenna.
axelC
Re: Glonass
by axelC Fri Jun 17, 2016 2:30 pm
Our company may need it, so it would be great to have it added in your SDK
Walmore
Re: Glonass
by Walmore Fri Jun 16, 2017 12:58 pm
I want to test the funcionality of the gps device using Glonass, so what do I have to change to use glonass ?.
Can I change some instruction or configuration in the libraries?
thanks!
Return to Geolocalization
Users browsing this forum: No registered users and 7 guests
