Glonass
Posted: Fri May 27, 2016 9:33 am
by axelC
The TD1204 is glonass compatible.
Does that mean that it automatically switch to glonass instead of gps if it is better or does it has to be set manually?
Re: Glonass
Posted: Fri Jun 17, 2016 1:44 pm
Glonass is off by default. Unfortunately we don't have any API to enable it yet. I guess we might be able to provide it if needed.
Please note that this will increase consumption and will require having a GPS and Glonass compatible antenna.
Re: Glonass
Posted: Fri Jun 17, 2016 2:30 pm
by axelC
Our company may need it, so it would be great to have it added in your SDK
Re: Glonass
Posted: Fri Jun 16, 2017 12:58 pm
by Walmore
I want to test the funcionality of the gps device using Glonass, so what do I have to change to use glonass ?.
Can I change some instruction or configuration in the libraries?
thanks!
