problems with gecko
by escalanterj Thu Apr 27, 2017 8:22 pm
Either my gecko or evk arre not working and are burning my modules, can someone tell me which quick and cheap alternative do I have to programm my TD1205 ?
thansks
Re: problems with gecko
by mstempin Mon May 15, 2017 7:54 am
You have to launch the energyAwareCommander.exe Flash tool and make sure the "Dbug Mode" is set to "Out" to access the TD RF module instead of the on board EFM32 when it is set to the default "MCU" mode.
Depending on the STK3300 firmware version, this setting is kept between power cycles or not.
