santiagolopez
I can't get the GPS signal.
by santiagolopez Fri Feb 17, 2017 12:01 pm
Hi all,
I'm trying to get the GPS signal with a TD1205p but I have some problems.
I have loaded the td1205P_modem_SOFT2067.bin firmware with TDloader.exe. I can acces to the device via serial:
But, when I have tryed to get the GPS signal with the AT command: AT$GPS=1,16,0,65535,1,1 I don't get any information.
also with this command: AT$GPS=1,4,900,180,2,2
I never get any GPGGA response
I don't know what i'm doing wrong, Can anybody helpme?
aoc
Re: I can't get the GPS signal.
by aoc Fri Feb 17, 2017 4:01 pm
First of all, I am not using TD1205P, but I guess TD GPS functions are the same.
santiagolopez wrote:But, when I have tryed to get the GPS signal with the AT command: AT$GPS=1,16,0,65535,1,1 I don't get any information.
The hdop can't be zero as dilution of precision won't be null. A value of 500 is quite correct.
The 16 satellites in view may be too much. A value of 4 or 5 is enough.
santiagolopez wrote:also with this command: AT$GPS=1,4,900,180,2,2
Here, the timeout may be too short. The GPS chip requires at least 30 seconds to get a position after a cold start.
If you're testing indoor, geolocation can be very long or might not succeed. You should test outdoor.
Also, the GPS antenna should be upward.
santiagolopez
by santiagolopez Mon Feb 20, 2017 8:48 am
Thanks you aoc. I will try with your indications. But these commands are from official documentation of TD1205p and I suppose there are correct.
aoc
by aoc Mon Feb 20, 2017 10:11 am
The second example will definitely work for outdoor applications.
Using GPS indoor, you should either increase hdop or timeout.
santiagolopez
by santiagolopez Mon Feb 20, 2017 3:22 pm
aoc wrote:The second example will definitely work for outdoor applications.
I just have tried in outdoor and the results are the same, I don't get any GPS signal. I only get the time, but not the localization. What am I forgetting?
aoc
by aoc Thu Feb 23, 2017 3:54 pm
I don't know how I can help.
Being indoor, 1 meter from a large window, I have tried AT$GPS=1,4,1000,65000,1,1 on my TD1204 EVB and I have got a position in 5 minutes.
I tried the same command 15 minutes later and couldn't get any position in 20 minutes.
santiagolopez
by santiagolopez Thu Mar 02, 2017 1:38 pm
aoc wrote:I don't know how I can help.
I have a question, when you send the AT command, you get an OK answer immediately? I can't understand why I can't get the GPS signal... I have tried with three different boards.
aoc
by aoc Tue Mar 07, 2017 2:43 pm
santiagolopez wrote:I have a question, when you send the AT command, you get an OK answer immediately?
Sometimes yes, sometimes almost.
Users browsing this forum: Naillbizdyeby, pamelalw2 and 1 guest
