How to create New project in Eclipse IDE
by Capture Wed Jun 10, 2015 8:53 am
i am trying to create new project in Eclipse IDE ,can anyone suggest me the procedure how to create the project and also how to link the library files to that project in a proprer method
Re: How to create New project in Eclipse IDE
by lcheminade Wed Jun 10, 2015 8:57 am
The easiest way is to copy/paste an existing project (preferably one which is the close to your application). You should be able to rename and change the destination folder without any dependency issue.
by Capture Wed Jun 10, 2015 9:27 am
Thank you for your kind reply i will do like that
tdnexteam
Site Admin
by tdnexteam Wed Jun 10, 2015 9:49 am
@Capture: please post in an appropriate section!
This particular section is for sharing projects, see http://community.td-next.com/viewtopic.php?f=8&t=7.
A more appropriate section for this kind of message would be "Firmware" or "General".
Thanks!
