Archie
TD1205p battery
by Archie Tue Dec 20, 2016 7:48 am
I plugged a 3V battery on the 1.2 pin but the TD is not powered.
I saw on the TD a 2 pin should make a welding?
TD1205 alimentation.jpg (3.11 KiB) Viewed 31512 times
gideonBreo
Re: TD1205p battery
by gideonBreo Thu Feb 09, 2017 3:15 pm
Same Problem Here on multiple TD1205P !!!
yluque
Re: TD1205p battery
by yluque Thu Feb 09, 2017 3:33 pm
It is Chevron which is dedicated to un-passivation battery process. If you not used this process, you must to weld this chevron.
jagusti
Re: TD1205p battery
by jagusti Thu Feb 09, 2017 9:49 pm
I bought 15 td1205p and all have the same problem. It's not possible to power the device in this way.
Regards
Josep
gideonBreo
Re: TD1205p battery
by gideonBreo Fri Feb 10, 2017 1:09 pm
So yes you must connect these 2 bits in order to power a 1205P with a Battery.
jagusti
Re: TD1205p battery
by jagusti Sun Feb 12, 2017 7:20 pm
gideonBreo wrote:So yes you must connect these 2 bits in order to power a 1205P with a Battery.
Yes. It works connecting the 2 bits.
Thanks for your help.
Regards
santiagolopez
Re: TD1205p battery
by santiagolopez Thu Feb 16, 2017 11:18 am
And it's possible to connect a fully charge LiPO battery? In every datasheet, the Vmax is 3,6V, but a fully charge battery drops 4,2v. It's possible to damage the TD1205p ?
Walmore
Re: TD1205p battery
by Walmore Sat Mar 18, 2017 8:08 pm
santiagolopez wrote:And it's possible to connect a fully charge LiPO battery? In every datasheet, the Vmax is 3,6V, but a fully charge battery drops 4,2v. It's possible to damage the TD1205p ?
Hello!, I have the same question, becouse I saw in a project the TD1205P supply by a Lipo battery but in the datasheet Vmax is 3.6V. Have you tried to test this?
Walmore
Re: TD1205p battery
by Walmore Sat Mar 18, 2017 8:09 pm
Have Somebody tried to supply the TD1205P by a Lipo battery?
Re: TD1205p battery
by mstempin Wed Apr 12, 2017 2:47 pm
The provided absolute maximum ratings are there because of good reasons, mainly internal components that are not guaranteed to continue working if you go beyond these values.
If you don't respect the absolute maximum ratings from the datasheet, then you are on your own!
You may put a diode in series in order to get a sufficient voltage drop, but I never tried.
