gdillen
TD-next TD1208 - AT$ problem
by gdillen Wed Apr 27, 2016 3:31 pm
I’m currently prototyping (POC) an IoT solution with an TD1208 EVB. I use the TD1208 EVB connected to an UART of an MCU (FRDM-K64F). I can send/receive commands (eg ATZ, AT&V, …) successfully, however all commands AT$… (starting with a $) don’t work. Any idea why’s that? Additionally, I thought both devices connections needs to be crossed: TX>RX, RX->TX. However, when doing it ts way even the ATZ, AT&V doesn't work.
I hope someone can help.
Many thanks.
Guy
