abrownlie
Cant Recieve Downlink/Acknowledgement
by abrownlie Tue Oct 27, 2015 9:59 am
When I use the AT$SB AT command with the TD1208 module I am able to send the bit but I am not able to receive an acknowledgement/down-link during the 20s receive period.
I have a feeling that this might configuration problem, does anyone know how to set this up? Thanks in advance for any help given.
Re: Cant Recieve Downlink/Acknowledgement
by mstempin Mon Nov 09, 2015 9:09 am
There is no specific configuration for downlink.
Make sure you have the latest firmware installed, then append the number of retries (should be 2) as second argument to the AT$SB command, and set the downlink flag to true (1) as third argument to the command.
