Zirco
Where is the sample code and the software stack
by Zirco Tue Oct 20, 2015 6:18 pm
Hello All,
I am new to the community and I feel a little stupid because I can't find the source code of the stack and the sample codes associated to the SDK. On the web page http://rfmodules.td-next.com/sdk/ it's written to get the code on Github. I can't find it in the https://github.com/Telecom-Design/ repo (only the doc repo is present). Can you point me the software repo ? Any advice and explanation welcome.
Zirco
Re: Where is the sample code and the software stack
by mstempin Fri Oct 23, 2015 9:50 am
Hi Zirco,
If you don' t already have one, you must create an account on Github first. Then log in to your TD developer account and provide your Github login (not password) in your profile panel under the "Github" tab.
Doing so will grant you access to a private "TD_RF_Module_SDK" repository on Github, where you will find the required samples and software stack.
This procedure is detailed here.
Users browsing this forum: BruceToipt, JerryDow, LloydJen, WilliamPeary, yasuperposter and 2 guests
