When I debug the accelero_data, accelero_event and geoloc_fix example the program stays in a trap with the value "TRAP_SPI_NOT_AVAILABLE".
I have the TD1205 module, I also changed the module nwith another TD1205 module.
Because there is not debug way for the TD1205 I chose for the TD1204 because this should be compatible.
What do I do wrong?
And is there more documentation? Because I only can find the datasheet from the module.
