Archie
change rate uart
by Archie Thu Jun 15, 2017 6:01 pm
I have multiplexed the serial link on 2 components that have different rate. My 2 tests programs work very well.
But, on the other hand, I can not reset the serial link with a different rate in the same program.
What is the procedure for doing this?
Re: change rate uart
by dandavid3000 Fri Jun 16, 2017 8:51 am
Archie wrote:Hello,
You can configure the braud rate like this
TD_UART_Options_t options = {LEUART_DEVICE, LEUART_LOCATION, 9600, 8, 'N',
                  1, false};
TD_UART_Open(&options, TD_STREAM_RDWR);
If you don't use the braudrate 9600, you can close it create another one and open it.
or you can use this function
void TD_UART_SetBaudrate(TD_STREAM_t *stream,uint32_t baudrate);
PS: You can find this piece of code in some TD examples.
Users browsing this forum: No registered users and 6 guests
