Disable I2C
by dandavid3000 Wed May 31, 2017 1:21 pm
I'd like to disable I2C in some situations. Is it the correct way to turn it off ?
I2C_Enable(I2C0, false);
GPIO_PinModeSet(SDA_PORT, SDA_BIT, gpioModeDisabled, 0); //Disable SDA
GPIO_PinModeSet(SCL_PORT, SCL_BIT, gpioModeDisabled, 0); //Disable SCL
CMU_ClockEnable(cmuClock_I2C0, false);
Dan
Re: Disable I2C
by mstempin Fri Jun 02, 2017 7:22 am
Hi Dan,
By default, the I2C is not enabled, so there is nothing particular to do to disable it.
If you want to do so, you should remove the route of the I2C peripheral to the actual chip pins.
Re: Disable I2C
by dandavid3000 Thu Jun 08, 2017 10:15 am
Thank you mstempin :D
Users browsing this forum: No registered users and 25 guests
