Can I use this function at init stage to change the UL central frequency: TD_SIGFOX_SetRFConfig(TD_SIGFOX_RF_config_t *config); ?
What should be the unit of central_frequency in that structure ?
typedef struct {
uint32_t central_frequency; ///< Central frequency
uint16_t max_channel; ///< Maximum allowed channel number
uint16_t channel_width; ///< Channel width in Hz
uint8_t power_level; ///< Power level in dBm
} __PACKED TD_SIGFOX_RF_config_t;
