thomas110594
library math.h
by thomas110594 Wed Nov 09, 2016 10:15 am
Hi everyone,
I'm using a TD1204 and I want to use the math.h library. It seems that eclipse compile and generate the bin file, but nothing happened on the module.
How can I use the pow and sqrt function? Do I have to create approximative function?
Thank you
gideonBreo
Re: library math.h
by gideonBreo Mon Nov 21, 2016 3:47 pm
Did you find any solution, I was thinking using the "arm-math.h" lib, but I still have some issues even with ARM_MATH_CM3 defined.
Regards
gideonBreo
Re: library math.h
by gideonBreo Tue Nov 22, 2016 8:31 am
did you enable the FPU ?
Re: library math.h
by mstempin Mon Nov 28, 2016 2:19 pm
There is no FPU onboard.
I personally don't use the math functions at all in such a low-power embedded MCU, as they tend to increase considerably the firmware size, as software floating point functions are linked in.
If you are trying to use sqrt() for computing a vector norm, I suggest to try the fast inverse square root trick:
https://en.wikipedia.org/wiki/Fast_inverse_square_root
