TD_SCHEDULER_Remove
by ramon2015 Mon Oct 24, 2016 5:42 pm
TD_SCHEDULER_Remove function is supposed to:
"Remove a timer from the scheduler. "
But not sure if it is doing it properly. The callback is not called after having removed the timer, but the timer is running so the mcu is awaken when time is up.
Is this normal?
Is there any way to avoid the timer to cause a wakeUp?
