Taf
USB->UART-is possible flash firmware?
by Taf Fri Sep 30, 2016 7:03 am
Is possible to flash TD1205P with UART only?
I haven't EVB for this module.
I tried a lot of UART flashing programs, but nothing works.
When I run TD Loader, then only Synchronizing... is showed (if I do reset before) or "Did not get local ACK". I know, choosed product is TD1205 EVB and I don't have EVB.
Comunication over UART and Putty works fine.
Can anyone help me with first steps with this module/connection?
Re: USB->UART-is possible flash firmware?
by mstempin Mon Nov 28, 2016 3:24 pm
The EVB is not required for UART firmware upgrade.
If you have the connections right for sending AT commands / receiving responses, you should be fine using the TDLoader.exe. In fact, it will start by sending an ATZ command @ 9600 bps to reset the module, then engage a communication with the bootloader @ 115200 bps. Please make sure to select TD1205 in the drop-down liste for the board model.
by escalanterj Tue Jan 24, 2017 10:14 pm
Could you guys tell me which is the right connection of the 1205P to an old module in order to programm it?
thanks
BEST
jagusti
by jagusti Thu Feb 09, 2017 10:11 pm
Taf wrote:Is possible to flash TD1205P with UART only?
Hi Taf
I have the same problem as you
Did you solve the problem?
Josep
