TD1205 and SDK 6
Posted: Mon Sep 12, 2016 10:29 am
Hi.
I experienced the following issue compiling TD1205 projects with SDK 6
If I compile with SDK 5 all works OK, but if I compile with SDK 6 no problem but it's not possible to send messages to Sigfox.
In the same way, if I load the firmware: td1205_modem_SOFT1632, I can send messages to Sigfox, but if I load firmware: td1205_modem_SOFT2066 it's not possible to send messages to Sigfox.
With TS1208 all works OK with both SDK and the new firmware.
Has someone experienced this issue?
Note: Mi TD1205 is Hardware version 01 . I don't know if this can affect...
Josep
Josep
