jagusti
TD1205 and SDK 6
by jagusti Mon Sep 12, 2016 10:29 am
Hi.
I experienced the following issue compiling TD1205 projects with SDK 6
If I compile with SDK 5 all works OK, but if I compile with SDK 6 no problem but it's not possible to send messages to Sigfox.
In the same way, if I load the firmware: td1205_modem_SOFT1632, I can send messages to Sigfox, but if I load firmware: td1205_modem_SOFT2066 it's not possible to send messages to Sigfox.
With TS1208 all works OK with both SDK and the new firmware.
Has someone experienced this issue?
Note: Mi TD1205 is Hardware version 01 . I don't know if this can affect...
Josep
Re: TD1205 and SDK 6
by mstempin Mon Nov 28, 2016 3:33 pm
Hi Josep,
This issue is strange. You can check on the Sigfox backend if there are no sequence number break that prevent from decoding the messages. In this case, please reset the sequence number when moving to a more recent firmware (normally not needed).
by francois Mon Nov 28, 2016 5:35 pm
Do you have any update on this issue.
We have the same issue using the SDK6 and the TD1508.
We can compile the project. We can manage to make the blink project working but the sigfox project doesn t work. No Sigfox transmission.
Francois
by mstempin Tue Nov 29, 2016 2:59 pm
It is not at all the same issue: OP is migrating a TD1205 project from SDK5 to SDK6, whereas the TD1508 is SDK6 only.
