I would like to know if it is possible to use IAR compiler with TD_RF_Module_SDK-v6.2.0 stack.
In previous project, I am using IAR environment and I do not want to use eclipse.
I tried to link the library but it does not seem to be compatible with what IAR is expecting (on wchar_t size for instance).
Is it possible to get the sigfox library recompiled with different compilation option?
Regards
Stéphane
