Undefined reference in function TD_GEOLOC_Init()
Posted: Fri Aug 12, 2016 9:40 am
Hi!
I was trying to add an ACC based event in my code when it would not compile any more. To be sure, I went back to the previous version of the code without the callback and tried to initialize the ACC and Geoloc with TD_GEOLOC_Init(); and TD_ACCELERO_Init();
The console reports this while compiling:
This are the paths in the project for eclipse under GNU C:
Also, I'm able to compile all the examples for the ACC/GEOLOC library.
Any idea of the cause of this behavior? Thanks for your time!
Germán
- Code: Select all
11:31:29 **** Incremental Build of configuration TD1204 Release for project gosi_v01 ****
Info: Internal Builder is used for build
arm-none-eabi-gcc -DNDEBUG -DEFM32G210F128 -DMODULE_REVISION=REVISION_TD1204 "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\workspace\\gosi_v01\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdgeoloc\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdsensor\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtddrivers\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\EnergyMicro\\EFM32G\\Include" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\CMSIS\\Include" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdtools\\inc" -Os -ffunction-sections -fdata-sections -Wall -c -fmessage-length=0 -mcpu=cortex-m3 -mthumb -o "src\\gosi_v01.o" "..\\src\\gosi_v01.c"
arm-none-eabi-gcc "-T..\\..\\Device\\EnergyMicro\\EFM32G\\Source\\G++\\efm32g.ld" -Xlinker --gc-sections "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdgeoloc\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdtools\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdsensor\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\GCC Release" -Wl,-Map,gosi_v01.map -mcpu=cortex-m3 -mthumb -o gosi_v01.elf "src\\gosi_v01.o" -ltdgeoloc -ltdtools -ltdsensor -ltdrf -ltdcore -lemlib -lDevice -lgcc -lc -lcs3 -lcs3unhosted
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_geoloc.o): In function `TD_GEOLOC_Init':
td_geoloc.c:(.text.TD_GEOLOC_Init+0x6): undefined reference to `TD_UBX_PARSER_Init'
td_geoloc.c:(.text.TD_GEOLOC_Init+0x12): undefined reference to `TD_UBX_PARSER_SetDataPointer'
td_geoloc.c:(.text.TD_GEOLOC_Init+0x1e): undefined reference to `TD_UBX_PARSER_SetDataPointer'
td_geoloc.c:(.text.TD_GEOLOC_Init+0x2c): undefined reference to `TD_UBX_PARSER_SetDataPointer'
td_geoloc.c:(.text.TD_GEOLOC_Init+0x38): undefined reference to `TD_UBX_PARSER_SetDataPointer'
td_geoloc.c:(.text.TD_GEOLOC_Init+0x3c): undefined reference to `TD_UBX7_Init'
td_geoloc.c:(.text.TD_GEOLOC_Init+0x94): undefined reference to `TD_FLASH_InitLogger'
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_accelero.o): In function `TD_ACCELERO_PowerDown':
td_accelero.c:(.text.TD_ACCELERO_PowerDown+0x1e): undefined reference to `TD_LIS3DH_Configure'
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_accelero.o): In function `TD_ACCELERO_Init':
td_accelero.c:(.text.TD_ACCELERO_Init+0x42): undefined reference to `TD_LIS3DH_Init'
td_accelero.c:(.text.TD_ACCELERO_Init+0x96): undefined reference to `TD_LIS3DH_ClearIRQ'
td_accelero.c:(.text.TD_ACCELERO_Init+0xda): undefined reference to `TD_LIS3DH_ClearIRQ'
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_accelero.o): In function `TD_ACCELERO_LowPower':
td_accelero.c:(.text.TD_ACCELERO_LowPower+0x24): undefined reference to `TD_LIS3DH_Configure'
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_accelero.o): In function `TD_ACCELERO_MonitorEvent__DYNAMIC':
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0x9e): undefined reference to `TD_LIS3DH_ConfigureEvent'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0xaa): undefined reference to `TD_LIS3DH_ConfigureInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0xb8): undefined reference to `TD_LIS3DH_ConfigHighPass'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0xbc): undefined reference to `TD_LIS3DH_ClearIRQ'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0xc8): undefined reference to `LIS3DH_EnableInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0xde): undefined reference to `LIS3DH_DisableInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0xe6): undefined reference to `TD_LIS3DH_ConfigureInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0x104): undefined reference to `LIS3DH_DisableInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0x10c): undefined reference to `TD_LIS3DH_ConfigureInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0x116): undefined reference to `TD_LIS3DH_ConfigureEvent'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0x11a): undefined reference to `TD_LIS3DH_ClearIRQ'
td_accelero.c:(.text.TD_ACCELERO_MonitorEvent__DYNAMIC+0x122): undefined reference to `TD_LIS3DH_ConfigHighPass'
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_accelero.o): In function `TD_ACCELERO_Power':
td_accelero.c:(.text.TD_ACCELERO_Power+0x26): undefined reference to `TD_LIS3DH_Configure'
C:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\libtdgeoloc\GCC Release\libtdgeoloc.a(td_accelero.o): In function `TD_ACCELERO_MonitorData__DYNAMIC':
td_accelero.c:(.text.TD_ACCELERO_MonitorData__DYNAMIC+0x7a): undefined reference to `LIS3DH_EnableInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorData__DYNAMIC+0x86): undefined reference to `TD_LIS3DH_ConfigureInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorData__DYNAMIC+0xb4): undefined reference to `TD_LIS3DH_SetFIFOMode'
td_accelero.c:(.text.TD_ACCELERO_MonitorData__DYNAMIC+0xd0): undefined reference to `LIS3DH_DisableInterrupt'
td_accelero.c:(.text.TD_ACCELERO_MonitorData__DYNAMIC+0xdc): undefined reference to `TD_LIS3DH_SetFIFOMode'
td_accelero.c:(.text.TD_ACCELERO_MonitorData__DYNAMIC+0xe0): undefined reference to `TD_LIS3DH_ClearIRQ'
collect2.exe: error: ld returned 1 exit status
11:31:30 Build Finished (took 703ms)
Germán
