by thomas110594 Fri Jul 08, 2016 10:09 am
Yes I call the geloc_init and accelero_init only once at the TD_USER_Setup function.
void TD_USER_Setup(void)
TD_UART_Options_t options = {LEUART_DEVICE, LEUART_LOCATION, 9600, 8, 'N',
1, false};
// Open an I/O stream using LEUART0
TD_UART_Open(&options, TD_STREAM_RDWR);
// Set flash variables version
TD_FLASH_DeleteVariables();
// Set the device as a Sensor transmitter
TD_SENSOR_Init(SENSOR_TRANSMITTER, 0, 0);
// Geoloc and accelerometer initialization
TD_GEOLOC_Init();
TD_ACCELERO_Init();
// Start GPS forever
TD_GEOLOC_TryToFix(TD_GEOLOC_NAVIGATION, TD_GEOLOC_INFINITE, GPSFix);
// Monitor accelerometer data-
TD_ACCELERO_MonitorData(true,
true,
TD_ACCELERO_50HZ,
TD_ACCELERO_ALL_AXIS,
TD_ACCELERO_8G,
0,
TD_ACCELERO_STREAMFIFO,
31,
DataCallback);
Like this it doesn't work... In the respective callback function, I just print some value.
