axelC
Issue using TD_UART_GetChar
by axelC Wed Jun 22, 2016 4:40 pm
I have an issue implementing UART reading and TD_UART_GetChar function.
With SDK 6.3.2 on a TD1204
I init my uart line in TD_USER_Setup()
   init_printf(TD_UART_Init(   9600,   //Baudrate
                        true,    //RX Enable
                        true),   //Pin Shared
            TD_UART_Putc,
            TD_UART_Start,
            TD_UART_Stop);
and I just did a first test in TD_USER_Loop() with:
   while ((c = TD_UART_GetChar()) >= 0) {
      tfp_printf(   "char : %c - %x\r\n", c, c);
After the execution of TD_USER_Setup(void) I have an infinite return on serial port (without pressing any key) full of :
char : ÿ - ff
char : ÿ - ff
char : ÿ - ff
char : ÿ - ff
char : ÿ - ff
I tried to add
GPIO_PinModeSet(RX_PORT, RX_BIT, gpioModeInput, 0);
Before the uart init but it make the same issue.
For info, I have a led on the tx pin but nothing on the rx pin. That why I use the Pin Shared function. Could it be the issue?
But I have the same comportment with
                        true,    //RX Enable
                        false),   //Pin Shared
            TD_UART_Putc,
            TD_UART_Start,
            TD_UART_Stop);
Does anyone know why the TD_UART_GetChar function would always return 0xFF?
axelC
Re: Issue using TD_UART_GetChar
by axelC Thu Jun 23, 2016 7:44 am
After a night of sleep I found the reason,
c was declared as char instead of int.
TD_UART_GetChar return an int that can be cast as char after the >= 0 test
Working code:
void TD_USER_Loop(void)
   int c;
   // Process geoloc events
   TD_GEOLOC_Process();
   // Process Accelerometer events
   TD_ACCELERO_Process();
axelC
by axelC Thu Jun 23, 2016 9:26 am
Actually I still have an issue,
I can't use the shared option.
When I put true to shared in :
                        true,    //RX Enable
                        true),   //Pin Shared
            TD_UART_Putc,
            TD_UART_Start,
            TD_UART_Stop);
The Rx function doesn't work anymore.
Only my tx pin is shared with a LED why the Rx doesn't work in shared mode?
axelC
by axelC Fri Aug 26, 2016 11:56 am
Same comportment with
    TD_UART_Options_t options = {   LEUART_DEVICE,
                                    LEUART_LOCATION,
                                    TEST_BAUDRATE, 8, 'N', 1,
                                    true};                     //Pin Shared
    TD_UART_Open(&options, TD_STREAM_RDWR);
