After sigfox Emit IRQ configuration changed
by disk91 Sat May 21, 2016 2:27 pm
I set an IRQ on DB3 and it works well.
It seems after a SigFox Send the IRQ is disabled (I mean I see no more call to my IRQ handler)
does it sounds like a normal behavior ?
Paul
Re: After sigfox Emit IRQ configuration changed
by disk91 Tue May 31, 2016 8:29 pm
up ... ?
any answer ?
by disk91 Sun Jun 19, 2016 3:24 pm
Still have some issue with IRQ activity once a sigfox transmission has been performed... any help ??
slm29
by slm29 Fri Sep 16, 2016 8:04 am
did you find a solution to your pb?
It seems that I have a similar problem.
I want to get interrupts during the sigfox message emission but they are disabled...
It is a bit annoying.
Slm
by disk91 Tue Nov 15, 2016 12:18 pm
Yes : SD6 fixed the issue
