axelC
De-Bounce delay
by axelC Thu May 12, 2016 9:51 am
I am using impulse counter on
gpioPortC pin 0
This is the pin 25 of td1204 (named V_IO)
I use this init procedure
// Set pin as input
   GPIO_PinModeSet(gpioPortC, 0, gpioModeInput, 0);
   //Set DOUT to 1 to activate filter, defined by tIOGLITCH (10-50ns)
   GPIO_PinOutSet(gpioPortC, 0);
   //Set configuration for pulse counter
   PCNT_Init_TypeDef pcntInit =
      .mode       = pcntModeOvsSingle,   // OvsSingle : Single input LFACLK oversampling mode
      .counter    = 0,               // Set initial value to 0
      .top        = 0xFFUL,            // Set top to max value
      .negEdge    = true,            // positive edges
      .countDown  = false,            // up count
      .filter     = true,               // filter enabled X
               // The filter passes all high and low periods that are at least 5 clock cycles long.
               // With LFACLK = 32kHz, 5xPeriode = 156us,
THe PCNT filter will be only 156us
That why i also try the Input filter with GPIO_PinOutSet(gpioPortC, 0);
But this filter is only 10-50ns
Do you think that there is a way to extend the filter around 100ms without adding an hardware filter on PCNT line?
