frederikv
Long transmission time
by frederikv Mon May 02, 2016 5:42 pm
What could be the cause the sending a message using the TD_SENSOR_SendDataPosition function take about a minute?
Also the whole module is blocked until this call is completed, is this normal.
I know that sending a message should be about 6 seconds but not 60 seconds.
When i remove this the TD_SENSOR_SendDataPosition from of the geoloc_fix_move example it keep running without 1-minute freeze.
Kind regards,
Frederik
