Time not set when fix >= TD_GEOLOC_TIME_FIX
by disk91 Sun Feb 14, 2016 11:51 am
When testing fix->type >= TD_GEOLOC_TIME_FIX and trying to access year, it returns 255 most of the time.
Works when waiting for longer time. So TIME_FIX seems not to be TIME_FIX ready
Trace in GPS callback :
if (fix->type >= TD_GEOLOC_TIME_FIX ) {
tfp_printf("year :%d\r\n",fix->datetime.year);
year :255
year :255
year :255
year :2016
Re: Time not set when fix >= TD_GEOLOC_TIME_FIX
by lcheminade Sun Feb 14, 2016 12:54 pm
Time isn't date! You would usually get time first, then date, then position. And no there isn't any TD_GEOLOC_DATE_FIX indicator but you just need to check for year just as you did.
by disk91 Mon Feb 15, 2016 12:09 pm
lcheminade wrote:Time isn't date! You would usually get time first, then date, then position. And no there isn't any TD_GEOLOC_DATE_FIX indicator but you just need to check for year just as you did.
I found it myself ... shame on me ;)
