christophevg
TD1208 module doesn't allow downlink to be used
by christophevg Thu Dec 17, 2015 11:54 am
We ...
- ... have recently purchased a TD1208 SigFox module for the development of a prototype for an IoT product.
- ... use the UART interface and the AT commands to interact with the module
- ... have moved our account from the TD backend to the SigFox backend
We encountered problems with the use of the downlink: when requesting a downlink, this request doesn't reach the SigFox backend.
E.g.: when we try the example from the TD1208 reference manual: AT$SF=33 31,2,1
We contacted SigFox support and went through a few interactions to debug the problem. A few commands were used to identify the module:
ATI7
1695A
TDID: 452001265753
OK
AT&V
Telecom Design TD1208
Hardware Version: 0F
Software Version: SOFT1351
S/N: 0001695A
TDID: 452001265753
ACTIVE PROFILE
E1 V1 Q0 X1 S200:0 S300:24 S301:2 S302:14 S303:1 S400:000000 S401:FFFFFFF S402:0 S403:869412500 S404:14 S405:32
AT$IF?
868200000,200,20
So far, everything seemed fine, but when requesting the downlink frequency, it seems this fails...
OK
AT$DR?
ERROR
Also setting these parameters fails:
AT$IF=868130000,200,20
OK
AT$DR=869525000
ERROR
What would be a next step to resolve this problem?
Christophe VG
nestorayuso
Re: TD1208 module doesn't allow downlink to be used
by nestorayuso Thu Dec 17, 2015 1:50 pm
update firmware
christophevg
by christophevg Fri Dec 18, 2015 8:26 am
After another review we have found a solution:
In the manual it states that the Send Frame command is supported as of SOFT1445 and according the the AT&V command, our module was at SOFT1351 … So it was logical the command didn’t succeed. After upgrading to SOFT1451 I just managed to send AND receive a frame.
Thanks for stressing this once again, which made us take a second look, thus noticing the old software version we had.
by mstempin Mon Dec 21, 2015 2:23 pm
Yes, although the commands are implemented in the SOFT1351 firmware, downlink is only supported since SOFT1445, and the Sigfox-certified firmware for the TD1208 is SOFT1451.
