CW mode (TD1204 / TD1208)
by ramon2015 Thu Nov 19, 2015 6:14 pm
I am trying to set the CW mode in my FW for a TD1204 module, but I think I need some assistance.
I found a function :
void TD_SIGFOX_TestCarrier ( uint32_t level, uint32_t frequency, bool high_performance )
which I think could do the job, but not sure.
I tried it and I got a hard fault message through the serial port (see attached picture). but maybe it is only due to a bad parameter...I dont know.
Fault condition dump via serial
From other post (viewtopic.php?f=3&t=114) I saw we should use AT command :
AT$MT=x,2,0
But I could not find such command in the SDK and see which is the function to use.
Which function should I use for both TD1204 and TD1208 turining in CW mode?
Is it an infinite function or shall i call it periodically?
Thanks in advance !
Re: CW mode (TD1204 / TD1208)
by ramon2015 Thu Nov 19, 2015 6:19 pm
By the way, when I invoked the function i did it as follows:
TD_SIGFOX_TestCarrier(10,868130000,true); /// crashed !!!
TD_SIGFOX_TestCarrier(14,868130000,true); /// crashed !!!
by omlu Wed Dec 09, 2015 10:05 am
I know it's been a while but I am also looking for how to activate CW mode on a TD1204.
Have you managed to put your device into CW mode? If yes, how?
by lcheminade Wed Dec 09, 2015 10:08 am
Sorry for the late reply.
You need to do a normal frame emission first to make sure the radio has been initialized:
TD_SIGFOX_Send("init",4,2);
Then forever CW mode is:
TD_SIGFOX_SendTestPA(0, 4,127, 868130000);
Last argument being the frequency.
by omlu Tue Jan 26, 2016 1:51 pm
lcheminade wrote:Then forever CW mode is:
TD_SIGFOX_SendTestPA(0, 2,127, 868130000);
Should the call of 'TD_SIGFOX_SendTestPA(0, 2,127, 868130000);' function be placed in a never ending loop?
Because I did as you said above but Sigfox just called me from their certification lab to tell me the device doesn't stay in CW mode.
[EDIT]
Are any other operations prohibited once the device is in CW Mode?
by lcheminade Wed Jan 27, 2016 1:54 pm
Ok my bad here. Correct call is:
TD_SIGFOX_SendTestPA(0, 4 , 127, 868130000);
This one is correct CW mode and should not stop. You should be able to tell by looking at the consumption. A while(1) loop around will not hurt anyway since it's not a good idea to do anything else while using CW mode.
My apologies.
by omlu Thu Jan 28, 2016 10:00 am
Thank you.
I hope it works. I don't think there is a way for me to check if it does, is there?
Where could I have found the information about TD_SIGFOX_SendTestPA()? In the libtdrf.chm file, there is nothing about parametring the mode with '4' (see image below).
Is there anyway I can access the definition of TD_SIGFOX_SendTestPA() (and lots of other functions used in the libraries whose definition are hidden) ?
by lcheminade Thu Jan 28, 2016 10:11 am
You can at least check the current is high. Of course a spectrum analyzer would be better.
For now we don't provide anything else. We know that our customers needs well documented test functions and this should be improved soon.
by omlu Mon Feb 01, 2016 4:04 pm
lcheminade wrote:You can at least check the current is high. Of course a spectrum analyzer would be better.
So I sent a second device with the new code for the CW mode to the certification lab ....and it still doesn't work.
Here is the function I call to enter CW mode:
void CWmode(void){
   TD_SCHEDULER_Remove(CWschedulerID);
   TD_SIGFOX_Send((uint8_t *)"CW mode",7,2);
   while(1) {
      TD_SIGFOX_SendTestPA(0, 4, 127, 868130000);
I did as you told me to. What seems to be the problem then?
PS: CWschedulerID is the ID of a scheduler calling a function checking if CW mode has been requested.
by lcheminade Mon Feb 01, 2016 4:14 pm
Is your scheduler callback called in interrupt? Could you please PM the full code?
