uzhtbq
ADC0 single voltage measurement
by uzhtbq Wed Nov 18, 2015 8:09 am
I'm trying to pick up single voltage measures from ADC0 pin
I already viewed the following posts :
- http://community.td-next.com/viewtopic.php?f=3&t=60
- http://community.td-next.com/viewtopic.php?f=3&t=102
I also made a manual measurement on the ADC0 pin when the module is OFF and my input voltage arrives well into the ADC0 pin (2V for example). But when I power the module, the manual measure is giving 0V on the pin.
I tried to use the function with following parameters : TD_MEASURE_SingleVoltage(adcSingleInpCh6, adcRef2V5) but having returns between 0mv and 5mv ...
I tried also to write my own function and changing init variables but with no success ...
Can anyone please show me how to get the right measure out of the ADC0 ?
Thanks in advance for your help
Re: ADC0 single voltage measurement
by lcheminade Wed Nov 18, 2015 8:30 am
Could you please share your schematics with us? Where does the voltage applied to the TD12xx come from?
You could try to set the pin as input beforehand: GPIO_PinModeSet(gpioPortC,0,gpioModeInput,0);
uzhtbq
by uzhtbq Fri Nov 20, 2015 5:28 pm
Many thanks, it worked for me ...
