Problems Uploading Firmware
Posted: Tue Oct 20, 2015 3:17 pm
by abrownlie
I'm having trouble uploading the firmware via the bootloader {TD Loader V1.06) to the TD 1208 board. It was working fine until I loaded the blink example onto the board and now I cant upload any other samples.
Any help that you can give me would be greatly appreciated.
Regards,
Andrew
Re: Problems Uploading Firmware
Posted: Wed Oct 21, 2015 5:05 pm
by mbolivar0
Hi all, I have encountered the same problem.
I don't know the answer but I'm replying here in order to give this post a little more importance.
Thanks.
Posted: Thu Oct 22, 2015 6:35 am
by ramon2015
Not totally sure, but the blink project does not inlcude a bootoloader, so if you want load a new FW you have to use the STK programmer instead.
Have a look at this issue:
viewtopic.php?f=10&t=24&p=507&hilit=bootloader#p507
Posted: Thu Oct 22, 2015 7:35 am
by abrownlie
I managed to figure it out. While the bootloader is synchronizing, removed the FDTI cable at the board end and then plug it back in. This resets the chip and allows you to upload a program with the bootloader.
I'm not sure if this is the safest way to do it but it worked for me. (Please dont blame me if it destroys your board :roll: )
Regards,
Andrew
