abrownlie
Problems Uploading Firmware
by abrownlie Tue Oct 20, 2015 3:17 pm
I'm having trouble uploading the firmware via the bootloader {TD Loader V1.06) to the TD 1208 board. It was working fine until I loaded the blink example onto the board and now I cant upload any other samples.
Any help that you can give me would be greatly appreciated.
Andrew
mbolivar0
Re: Problems Uploading Firmware
by mbolivar0 Wed Oct 21, 2015 5:05 pm
Hi all, I have encountered the same problem.
I don't know the answer but I'm replying here in order to give this post a little more importance.
by ramon2015 Thu Oct 22, 2015 6:35 am
Not totally sure, but the blink project does not inlcude a bootoloader, so if you want load a new FW you have to use the STK programmer instead.
Have a look at this issue:
viewtopic.php?f=10&t=24&p=507&hilit=bootloader#p507
abrownlie
by abrownlie Thu Oct 22, 2015 7:35 am
I managed to figure it out. While the bootloader is synchronizing, removed the FDTI cable at the board end and then plug it back in. This resets the chip and allows you to upload a program with the bootloader.
I'm not sure if this is the safest way to do it but it worked for me. (Please dont blame me if it destroys your board :roll: )
Andrew
Users browsing this forum: No registered users and 24 guests
