pmorali
CW Mode
by pmorali Wed Oct 14, 2015 12:05 pm
How to put a device in CW Mode for Sigfox Certification?
FOR CW MODE:
AT$SS=1234
AT$MT=0,2,127
To disable CW MODE : AT$MT=0,0,0
Is this correct?
jguerin
Re: CW Mode
by jguerin Thu Oct 15, 2015 7:57 am
Hi pmorali,
For a TD1207, you can put the device in CW mode with :
AT$MT=0,4,127
For a TD1204:
AT$MT=x,2,0
with x is a Sigfox micro canal.
Jerome
gomago
Re: CW Mode
by gomago Thu Dec 10, 2015 4:10 pm
From previous messages I understand that commands to operate the TD1207 in CW mode are:
CW enable: AT$MT=0,4,127
CW disable: AT$MT=0,0,0
Am I right?
Is it valid for 868.13MHz Standard ETSI band?
Thank you very much
Regards
Ignacio
Re: CW Mode
by francois Thu Mar 24, 2016 5:33 pm
What about the AT command to put the TD1208 in CW mode?
Francois
Re: CW Mode
by mstempin Fri Mar 25, 2016 8:26 am
It depends on the firmware version: for newer firmware, these should be the same commands as the TD1207, for older, please use "AT$MT=0,1,0" instead of "AT$MT=0,4,127".
Re: CW Mode
by francois Tue Apr 19, 2016 9:03 pm
Do you have "c" function in library to set the TD1208 device in CW mode ?
As an alternative to AT CMD.
Re: CW Mode
by mstempin Tue Aug 09, 2016 8:35 am
Yes, the corresponding C API functions are "TD_SIGFOX_SendTestPA()" for the old "AT$MT=" commands and "TD_RF_CWTest()" for the newest firmwares.
