giovanni
Put UART in High Z
by giovanni Wed Oct 07, 2015 7:47 am
To limit current leakage from the TD1204 uart we're disabling it when not in use.
However disabling it only limits leakage to 60uA (whilst not disabling it leaks 180uA).
Is there a possibility to do this? We're using the uart in combination with a USB-self-powered FTDI chip (so it's floating when not used, hence the current leakage).
Kind regards!
Re: Put UART in High Z
by lcheminade Wed Oct 07, 2015 7:51 am
Sounds like a lot of leakage... Are you sure this is due to the FTDI chip?
Anyway setting the pin in high Z can be done by using:
GPIO_PinModeSet(gpioPortD,4,gpioModeDisabled,0);
GPIO_PinModeSet(gpioPortD,5,gpioModeDisabled,0);
giovanni
by giovanni Wed Oct 07, 2015 9:00 am
Thanks Loic!
This did the trick, sleep current is back to 5uA.
Kind regards,
Giovanni.
