zeliuq
Re: Tx power management
by zeliuq Mon Sep 14, 2015 1:04 pm
Ok, thank you very much for your help
francoisR
by francoisR Thu Dec 08, 2016 9:18 am
I would like to get more informations about the TX power.
In the TD1207R datasheet, I read: "providing an exceptional output power of up to +16 dBm"
I know that ETSI limit is 14dBm, but the limitation is at the PA output. Like the TD1205, it's possible that I need to compensate some insertion loses.
I try with the command ATS302 to set the power at 15 or 16dBm, but I get an error.
So what I've to do to set the power output at the datasheet maximum ouput power at 3.3V power supply? (16dBm)
Thanks a lot for your anwer
François
Users browsing this forum: No registered users and 2 guests
