zeliuq
Scheduler timing max values
by zeliuq Mon Jul 06, 2015 10:03 am
I would like to know the max values for the timing parameters ("interval" and "delay") of the scheduling function "TD_SCHEDULER_Append".
They are both uint32_t but considering the the units are given in seconds there may be a limitation somewhere else.
Best regards
Re: Scheduler timing max values
by lcheminade Mon Aug 03, 2015 3:34 pm
First param is seconds and is uint32_t. Second is ticks and is uint16_t. There are no other restriction than the param size.
thomas110594
by thomas110594 Tue Jul 05, 2016 10:14 am
Bonjour,
Lors j'utilise la fonction TD_Scheduler_Append et que je fixe l'intervalle à 150s par exemple, cela fonctionne très bien. Or des que je dépasse 500s, cela ne fonctionne plus. Avez-vous une explication à ce problème?
Merci.
