mleeters
Accelerometer SPI unavailable
by mleeters Mon Jul 13, 2015 11:04 am
When I debug the accelero_data, accelero_event and geoloc_fix example the program stays in a trap with the value "TRAP_SPI_NOT_AVAILABLE".
I have the TD1205 module, I also changed the module nwith another TD1205 module.
Because there is not debug way for the TD1205 I chose for the TD1204 because this should be compatible.
What do I do wrong?
And is there more documentation? Because I only can find the datasheet from the module.
Re: Accelerometer SPI unavailable
by lcheminade Mon Jul 20, 2015 1:49 pm
Please see this topic to compile TD1204 code for TD1205:
viewtopic.php?f=10&t=72
