TD1508 in emulator mode
by ramon2015 Wed Nov 30, 2016 9:25 am
I amtrying to test our device based on TD1508 via a Sigfox Network emulator Mode, but it says I have to use an emulator mode inthe device. Do you have any idea howe to do this on the TD1508?
emualtor mode
emualtor mode.jpg (74.71 KiB) Viewed 2578 times
Re: TD1508 in emulator mode
by mstempin Wed Nov 30, 2016 2:02 pm
Hi Ramon,
In order to use the Sigfox SNEK network emulator, you have to use a public key, instead of the standard module private key.
Switching to the public key is achieved by using the following command before sending a Sigfox Frame:
AT$PID=1
This setting is not persistent, so you will have to set it again if you reset the module (this is a temporary test mode).
When using the SDK, the equivalent C API functions is:
bool TD_SIGFOX_SetPublicKey(bool public)
by ramon2015 Wed Nov 30, 2016 2:56 pm
Thanks for the answer. But still I do not see any message ariving at the SNEK.
I add my code here:
TD_SIGFOX_SetPublicKey(true);
   uint32_t channel_bitmask[3];
   //WARNING : TD_SIGFOX_SetDefaultMacroChannel must be set AFTER TD_SIGFOX_SetMacroChannelBitmask
   channel_bitmask[0] = CONFIG_SIGFOX_FCC_MACRO_CHANNEL_BITMASK_LSB;
   channel_bitmask[1] = CONFIG_SIGFOX_FCC_MACRO_CHANNEL_BITMASK_MID;
   channel_bitmask[2] = CONFIG_SIGFOX_FCC_MACRO_CHANNEL_BITMASK_MSB;
   TD_SIGFOX_SetMacroChannelBitmask(channel_bitmask);
   TD_SIGFOX_SetDefaultMacroChannel(CONFIG_SIGFOX_FCC_DEFAULT_MACRO_CHANNEL);
   //TD_SIGFOX_SetDownlinkOffset(3000000);
 TD_SIGFOX_SendV1(MODE_FRAME, false, data_payload, MESSAGE_SGX_MAX_LEN_12, 2, periodic_data.param_Flag, false);
Do i need to set the region on the TD1508 device? I do nto think so. anyway I have checked and it is number 2 (FCC).
D i need any further setting?
dandavid3000
by dandavid3000 Mon Dec 05, 2016 2:13 pm
Make sure this one should be modified too ramon
ramon2015 wrote:Hi,
I add my code here:
by mstempin Wed Dec 14, 2016 4:46 pm
No, the region should be set to 2 by default for the TD1508.
Be sure that this sequence is executed before any Sigfox transmission, the best is to perform it at the very beginning of the TD_USER_Setup() function.
