nullpointer
Developer API - Iot Application deletion
by nullpointer Sat Aug 15, 2015 8:11 am
I can't delete a Iot Application deletion. I've tried several patterns. Iot Applications listing & Iot Applications creation / update works fine
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d '{173217639}'
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d 'id=173217639'
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d "id=173217639"
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d "{id=173217639}"
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d "{id:173217639}"
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d "id:173217639"
$ curl -X DELETE -H "Authorization: Basic myToken=" "http://sensor.insgroup.fr/iot/developers/apps.json" -d "173217639"
csarrouilhe
Re: Developer API - Iot Application deletion
by csarrouilhe Tue Aug 18, 2015 8:24 am
correct syntax is :
curl -X DELETE -H "Authorization: Basic myToken=" "https://sensor.insgroup.fr/iot/developers/apps.json?id=173217639"
Best regards
Christophe
nullpointer
by nullpointer Wed Aug 19, 2015 7:51 am
It works, thanks
