mleeters
JSON data for backend
by mleeters Tue Jul 28, 2015 6:11 am
Do you have a detailed description from the JSON data dat is send to a backend?
The important part is the data that is send from a TD12xx module to the backend with the function TD_SIGFOX_Send
mleeters
Re: JSON data for backend
by mleeters Tue Jul 28, 2015 7:25 am
I found out why I didn't get the information.
This has to do with the UDM Frame Decoder, is there a way of function to put it out?
I just want to get my data, not the UDM decoded data.
by lcheminade Mon Aug 03, 2015 8:14 am
Please use TD_SENSOR_SendRaw to get up to 10 bytes of raw data. So far our backend does not allow to get the full 12 bytes payload in the callback.
mleeters
by mleeters Thu Aug 06, 2015 9:31 am
Thanks, this works better that use as the first two byte 0x00 and 0x14.
Users browsing this forum: No registered users and 18 guests
