arnaudw
best way to read with leuart
by arnaudw Fri Jun 26, 2015 10:01 am
I have a GPS which continuously send info on the RX pin.
What is the best way/practice to read from leuart ?
I think i should implement a buffer, then read it when it is full.
Found the declaration in the examples :
init_printf(TD_UART_Init(9600, true, false), TD_UART_Putc, TD_UART_Start,
         TD_UART_Stop);
Then, I found this on the web :
 while ((c = TD_UART_GetChar()) >= 0) {
But in my case, it will never stop if i use it like this.
Thanks in advance,
Arnaud.
Re: best way to read with leuart
by lcheminade Fri Jun 26, 2015 10:20 am
This should be fine. Did you declare c as an int?
arnaudw
by arnaudw Fri Jun 26, 2015 11:21 am
Yes, c is an int.
Ok if it is the good way, i will find how to proceed with buffer. I am a a beginner but i should find :)
Thanks Loïc.
(I think you are french as me but as we are on an internationnal forum... :mrgreen: )
by lcheminade Fri Jun 26, 2015 12:23 pm
The buffer already exist at the driver level. If you don't get out of the loop then this is probably because you never stop to have data. I guess your GPS keeps sending you some data. You'd better use 11500 speed when your gps is on and go back to 9600 when it is off.
arnaudw
by arnaudw Fri Jun 26, 2015 1:42 pm
Indeed it sends always data, either if there is no fix.
Good news that a buffer is already in the chip, so, if i understand, i only need to do this to get (always) the content by char.
int c;
char didi;
while (((c = TD_UART_GetChar()) >= 0)) {
didi = (char)c;
