Upgrade new SDK to old project
by dandavid3000 Tue Nov 08, 2016 2:06 pm
Currently I have a project working on SDK v5.0.0. TD has released a new version which is v6.0.0 and I'd like to update new SDK to my project.
My question is what is the correct way to import new SDK to my old project?
I was trying to copy new all libraries to my project and it caused problem that I couldn't solve. My project works perfectly with the old SDK.
I also tried to import new SDK from TD github and import my project inside and it caused the same problem above.
Dan
Re: Upgrade new SDK to old project
by mstempin Mon Nov 28, 2016 4:21 pm
The SDK provides a stable API (Application Programming Interface), not a stable ABI (Application Binary Interface). It means that binary libraries are not compatible between versions and you have to recompile them as they are compatible at the source-level.
The best way to migrate to the new SDK is to put them side by side on your C:\ drive, so you will be able to switch from one to the other without efforts. Then, launch the new SDK and import your projects into Eclipse using the File>Import. the best if you want to experiment is to make a copy of these projects instead of linking them in.
Users browsing this forum: No registered users and 18 guests
