thanks for your answer. I've changed the variable to replace the system's but it still causes the same error:
- Code: Select all
16:32:51 **** Incremental Build of configuration TD1204 Debug for project blink ****
Info: Internal Builder is used for build
arm-none-eabi-gcc -DDEBUG -DDEBUG_EFM -DEFM32G210F128 -DMODULE_REVISION=REVISION_TD1204 "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdgeoloc\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdsensor\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtddrivers\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\EnergyMicro\\EFM32G\\Include" -O0 -ffunction-sections -fdata-sections -Wall -c -fmessage-length=0 -mcpu=cortex-m3 -mthumb -g3 -gdwarf-2 -o "src\\blink.o" "..\\src\\blink.c"
Cannot run program "arm-none-eabi-gcc": El nombre del directorio no es válido.
16:32:51 Build Finished (took 246ms)
However, if I manually invoke the compiler through Windows console it is able to compile using this command sequence:
- Code: Select all
arm-none-eabi-gcc -DDEBUG -DDEBUG_EFM -DEFM32G210F128 -DMODULE_REVISION=REVISION_TD1204 "-IC:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\CMSIS\Include" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdgeoloc\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdsensor\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtddrivers\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\EnergyMicro\\EFM32G\\Include" -O0 -ffunction-sections -fdata-sections -Wall -c -fmessage-length=0 -mcpu=cortex-m3 -mthumb -g3 -gdwarf-2 -o "C:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\examples\\core\\blink\\src\\blink.o" "C:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\examples\\core\\blink\\src\\blink.c"
(You may notice I've added the path to "-IC:\TD\TD_RF_Module_SDK-v6.0.0\Github\TD_RF_Module_SDK\lib\CMSIS\Include" because without it the compiler wouldn't find "core_cm3.h" file)
Still, I am unable to work with the SDK in any useful way, is there any procedure to fix this?
I have recreated this error with both Windows 7 and Windows 10, both x64 architecture versions.
Thank you again
Germán
