lub
Build not working
by lub Wed Jul 20, 2016 9:15 pm
Whenever I try to build any of the projects I get the following message on the console
17:14:00 **** Incremental Build of configuration TD1508 Debug for project blink ****
Info: Internal Builder is used for build
arm-none-eabi-gcc -DDEBUG -DDEBUG_EFM -DEZR32LG230F128 -DMODULE_REVISION=REVISION_TD1508 "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdgeoloc\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdsensor\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtddrivers\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\EnergyMicro\\EFM32LG\\Include" -O0 -ffunction-sections -fdata-sections -Wall -c -fmessage-length=0 -mcpu=cortex-m3 -mthumb -g3 -gdwarf-2 -o "src\\blink.o" "..\\src\\blink.c"
Cannot run program "arm-none-eabi-gcc": The directory name is invalid.
17:14:00 Build Finished (took 265ms)
and no outputs are generated. I have followed carefully every step on the README.
Can anyone help me?
Thanks!
lopic34
Re: Build not working
by lopic34 Thu Feb 23, 2017 3:35 pm
I am trying to compil my first "blink" too, and I have the same problem:
16:28:36 **** Incremental Build of configuration TD1208 Release for project blink ****
arm-none-eabi-gcc -DNDEBUG -DEFM32G210F128 -DMODULE_REVISION=REVISION_TD1208 "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtddrivers\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\inc" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\EnergyMicro\\EFM32G\\Include" "-IC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\CMSIS\\Include" -Os -ffunction-sections -fdata-sections -Wall -c -fmessage-length=0 -mcpu=cortex-m3 -mthumb -o "src\\blink.o" "..\\src\\blink.c"
arm-none-eabi-gcc "-T..\\..\\Device\\EnergyMicro\\EFM32G\\Source\\G++\\efm32g.ld" -Xlinker --gc-sections "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdgeoloc\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdsensor\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdrf\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtddrivers\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\libtdcore\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\emlib\\GCC Release" "-LC:\\TD\\TD_RF_Module_SDK-v6.0.0\\Github\\TD_RF_Module_SDK\\lib\\Device\\GCC Release" -Wl,-Map,blink.map -mcpu=cortex-m3 -mthumb -o blink.elf "src\\blink.o" -ltdgeoloc -ltdsensor -ltdrf -ltdcore -ltdrf -ltddrivers -ltdcore -lemlib -lDevice -lgcc -lc -lcs3 -lcs3unhosted
c:/td/td_rf_module_sdk-v6.0.0/gnu/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld.exe: cannot find -ltdgeoloc
c:/td/td_rf_module_sdk-v6.0.0/gnu/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld.exe: cannot find -ltdsensor
c:/td/td_rf_module_sdk-v6.0.0/gnu/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld.exe: cannot find -ltdcore
c:/td/td_rf_module_sdk-v6.0.0/gnu/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld.exe: cannot find -lemlib
c:/td/td_rf_module_sdk-v6.0.0/gnu/bin/../lib/gcc/arm-none-eabi/4.7.2/../../../../arm-none-eabi/bin/ld.exe: cannot find -lDevice
collect2.exe: error: ld returned 1 exit status
16:28:39 Build Finished (took 2s.811ms)
Is it a local path configuration ?
Best regards,
Users browsing this forum: No registered users and 18 guests
