TD loader "did not get local ack"
Posted: Thu May 05, 2016 7:22 am
by francois
I got the following message from the TD_loader: "did not get local ack".
What this message stand for?
The target device is a TD1204.
Re: TD loader "did not get local ack"
Posted: Fri Aug 26, 2016 3:23 pm
by mariusmm
Hi Francois,
the same happens to me in some devices, but I don't know why.
do you have some answer or hint about this?
Regards,
Màrius
Posted: Mon Nov 28, 2016 4:29 pm
Please make sure you are able to communicate with the TD1204 using a terminal emulator software @ 9600 bps, 8 bits, no parity, 1 stop bit.
Close the terminal emulator first, then, when using the TDLoader.exe, please make sure to select the same COM port and the correct board "TD1204EVB".
