This category is for how-tos and tutorials for the TD RF modules and related projects.
robomotic
Issues registering EVB TD1208
by robomotic Fri Jul 24, 2015 10:37 am
Hello guys!
This is my first post in the forum so I hope to have chosen the right section!
So I have received the TD1208 EVB yesterday and followed the EVB steps one by one i.e. upgrading the firmware, sending a test packet and a registration request for the cloud .
I have found the following problems which I hope somebody can help me with:
[/list]
A dump of the AT&V is here:
Telecom Design TD1208
Hardware Version: 0F
Software Version: SOFT1451
S/N: 00016766
TDID: 452001035753
ACTIVE PROFILE
E1 V1 Q0 X1 S200:0 S300:24 S301:2 S302:14 S303:1 S304:20 S305:25 S350:0 S351:327
68 S352:1 S353:10 S400:000000 S401:FFFFFF S402:0 S403:869412500 S404:14 S405:32
S406:1
I have also the module key but I think that supposed to be secret, so will not post in the forum.
Any help is welcome!
Re: Issues registering EVB TD1208
by lcheminade Fri Jul 24, 2015 12:12 pm
Could you please try again now?
robomotic
by robomotic Fri Jul 24, 2015 9:28 pm
lcheminade wrote:Could you please try again now?
Excellent point 2 and 3 are solved now.
For the sigfox backend whom should I ask the PAC code?
by lcheminade Sat Jul 25, 2015 8:01 am
You'll find it under the Device dashboard !
nullpointer
by nullpointer Thu Jul 30, 2015 4:03 pm
Hi there,
I have a similar problem, A dump of the AT&V is here:
AT&V
Software Version: SOFT1291
S/N: 00015F32
TDID: 435001875753
ACTIVE PROFILE
E1 V1 Q0 X1 S200:0 S300:24 S301:2 S302:14 S303:1 S400:000000 S401:FFFFFFF S402:0 S403:869412500 S404:14 S405:32
I send the activation bytes as described but I never get past this form: https://developers.insgroup.fr/dashboards/device.html it's always telling me "OPPSSS"
any help will be appreciated
robomotic
by robomotic Sat Aug 01, 2015 2:24 pm
lcheminade wrote:You'll find it under the Device dashboard !
Awesome, I got everything working now ! Sorry for the late reply.
:shock:
kohagan
by kohagan Tue Apr 19, 2016 1:10 pm
Attempting to get two TD1208 EVB registered, same issues as others, device details are ;
No. 1
S/N: 00074AFB
TDID: 528000785753
ACTIVE PROFILE
No.2
S/N: 000748E7
TDID: 528000325753
ACTIVE PROFILE
Any assistance appreciated.
K.
kohagan
by kohagan Wed Apr 20, 2016 10:01 am
Experiencing same issue with two TD1208 EVB's. Cannot access device dashboard.
No. 1
S/N: 00074AFB
TDID: 528000785753
No. 2
S/N: 000748E7
TDID: 528000325753
Thanks,
K.
Archie
by Archie Wed Aug 03, 2016 6:48 am
I have a same probleme robotic.
if I record the modem I send the activation https://developers.insgroup.fr/dashboards/device.html, I would see in the backend of SIGFOX ?
by mstempin Tue Aug 09, 2016 7:57 am
All TD RF module EVBs are pre-registered to access the TD Dashboard service for one year. All you have to do is to go to the Dashboard and provide the board ID and key located on the sticker.
As the Sigfox backend callbacks are redirected to the TD Dashboard, you cannot access the Sigfox backend, but you get a similar display on the Dashboard under the "Raw" tab.
Return to Tutorials
